DTABLE
Bulk Data Entry List of constants to be used in functions defined by DEQATN.
DTABLE LABL1 VAL1 LABL2 VAL2 LABL3 VAL3 LABL4 VAL4
  LABL5 VAL5 etc
DTABLE W 123.00 H 321.00 B 55.55 AGE 21
  C 36.0 WST 24.0 HPS 35.0
LABLi Constant label.
(Character)
VALi Constant value.
(Real)
  1. If a DTABLE entry has a pair of blank fields, they are ignored. If there are other constants after the blank fields, they are read in.
  2. If fields are full of zeros, the constant label is "0", and the value is 0.0.
  3. Multiple DTABLE entries are supported in the Bulk Data section.
  4. This card is represented as an optimization table entry in HyperMesh.
