DTI,SPECSEL
Bulk Data Entry Correlates spectra lines specified on TABLED1 entries with damping values.
DTI | SPECSEL | ID | TYPE | TID1 | DAMP1 | TID2 | DAMP2 | ||
TID3 | DAMP3 | etc | etc | etc | etc | etc | etc | ||
etc | etc |
DTI | SPECSEL | 99 | A | 2 | 0.0 | 3 | 0.02 | ||
4 | 0.04 |
ID | DTI,SPECSEL
identification number. All
DTI,SPECSEL cards must
have unique identification numbers. No default (Integer > 0) |
TYPE | Spectrum type.
No default |
TID# | A
TABLED1 entry identification number that
defines a line of the spectrum. No default (Integer > 0) |
DAMP# | Damping value assigned to
TID#. No default (Real) |
- The TID#, DAMP# pairs list the TABLED1 entry, which defines a line of the spectrum and the damping value assigned to it. The damping value is in the units of fraction of critical damping.
- If only a single TID# and DAMP# pair is specified, the reference curves for different damping values will not be extrapolated from the specified values.
- Refer to Response Spectrum Analysis in the User Guide for more details.
