Bulk Data Entry Defines units for multibody, component mode
synthesis (flexible-body preparation), and Explicit Dynamic Analysis (EXPDYN)
sequences.
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
DTI |
UNITS |
1 |
MASS |
FORCE |
LENGTH |
TIME |
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
DTI |
UNITS |
1 |
KG |
N |
M |
S |
Field |
Contents |
SI Unit Example |
MASS |
Units of mass. 3
- klbm
- kilo pound-mass (1000.lbm)
FORCE |
Units of force. 3
- klbf
- kilo pound-force (1000.lbf)
LENGTH |
Units of length. 3
TIME |
Units of time. 3
- PARAM, WTMASS is ignored for the
multibody and component mode synthesis (flexible-body preparation) solution
sequences. Unit data for these solution sequences is supplied on the
DTI,UNITS Bulk Data Entry.
- This DTI,
UNITS Data Entry is the same as the UNITS entry.
- If the units defined on the
DTI,UNITS entry are not consistent,
mass unit is ignored, only force, length, and time units are considered in
Explicit Dynamic Analysis (EXPDYN) subcases.
- This card is represented as a control
card in HyperMesh.
