DVCREL1
Bulk Data Entry Relates Design Variables to Analysis Model Element Properties
Linearly relates a design variable to an analysis model element property using the equation:(1)
MPi=C0+iCOEFiDVIDi
DVCREL1 ID TYPE EID EPNAME/
FID
    C0
  DVID1 COEF1 DVID2 COEF2 etc.
ID Relationship identification number. ID must be unique with respect to other DVCREL1 cards.
No default (Integer > 0)
TYPE Element type to be related (DVCREL - Types)
No default (Character)
EID Element identification number.
EPNAME/FID Element property name, such as "K" or "ZOFFS" (as in the documentation of the element Bulk Data Entries), or field number on an element Bulk Data Entry.
No default (Character or Integer > 0)
C0 Constant in relationship equation.
Default = 0.0 (Real)
DVIDi DESVAR ID.
COEFi Coefficient in relationship equation.
Default = 1.0 (Real)
  1. This card is represented as an optimization design variable property relationship in HyperMesh.
