DVMBRL2
Bulk Data Entry Relates a design variable to properties of MBD entities using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and the constants defined on the DTABLE card.
DVMBRL2 | ID | PTYPE | BID/ EID |
PNAME | EQID | ||||
DESVAR | DVID1 | DVID2 | DVID3 | DVID4 | DVID5 | DVID6 | DVID7 | ||
DVID8 | DVID9 | etc. | |||||||
DTABLE | LABL1 | LABL2 | LABL3 | LABL4 | LABL5 | LABL6 | LABL7 | ||
LABL8 | etc. |
ID | Relationship identity. ID
must be unique with respect to other DVMBRL1 and
DVMBRL2 cards. No default (Integer > 0) |
TYPE | Property type to be
related. 1 No default (Character) |
BID/EID | Body ID or Element ID
number. When TYPE is PRBODY,
this field is the ID number of a rigid body. When
TYPE is CMBUSH(M),
CMBEAM(M), or CMSPDP(m), this
field is the ID number of a corresponding element. No default (Integer > 0) |
PNAME | Property name, such as "A"
or "L" (as in the documentation of the PRBODY,
CMBEAM(M), CMBUSH(M), and
CMSPDP(M) cards). No default (Character or Integer > 0) |
EQID | Equation ID of
DEQATN data. No default (Integer > 0) |
DESVAR | Indicates DESVAR ID numbers follow. | |
DVIDi | DESVAR
ID. No default (Integer > 0) |
DTABLE | Indicates DTABLE labels follow. | |
LABLi | Constant label on
DTABLE card. No default (Character) |
- Property type table:
- PRBODY
- IXX
- IYY
- IZZ
- IXY
- IXZ
- X
- X component of center of gravity.
- Y
- Y component of center of gravity.
- Z
- Z component of center of gravity.
- CMBEAM/CMBEAMM
- L
- Undeformed length along the X-axis of the beam.
- A
- Area of the beam cross-section.
- I1
- Area moment of inertia in plane 1 about the neutral axis.
- I2
- J
- Torsional constant.
- K1 ~ K2
- Area factor for shear.
- CMBUSH/CMBUSHM
- K1 ~ K3
- Translational stiffness.
- K4 ~ K6
- Rotational stiffness.
- B1 ~ B3
- Translational damping.
- B4 ~ B6
- Rotational damping.
- P1 ~ P3
- Translational preload.
- P4 ~ P6
- Rotational preload.
- CMSPDP/CMSPDPM
- K
- Stiffness
- B
- Damping
- L
- Unstretched length of spring damper.
- PF
- Preload force.
- This card is represented as an optimization design variable property relationship in HyperMesh.
