DVMREL2
Bulk Data Entry Relates design variables to an analysis model material property using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and constants defined on a DTABLE card.
DVMREL2 ID TYPE MID MPNAME/FID     EQID
  DESVAR DVID1 DVID2 DVID3 DVID4 DVID5 DVID6 DVID7
    DVID8 DVID9 etc.
  DTABLE LABL1 LABL2 LABL3 LABL4 LABL5 LABL6 LABL7
    LABL8 etc.
Example 1
To relate the Damping Coefficient value on a MAT1 card (field 9) to some user-defined relationship of design variables 5 and 6 and the table entry GE0.
DVMREL2 17 MAT1 22 9     1
  DESVAR 5 6
  DTABLE GE0
Example 2
This example is the same as , except that it defines MPNAME in place of FID.
DVMREL2 17 MAT1 22 GE     1
  DESVAR 5 6
  DTABLE GE0
Associated Cards
DESVAR 5 GE1 1.0 2.0 0.5
DESVAR 6 GE2 1.0 1.0 0.01
DTABLE GE0 0.01
DEQATN 1 GE(GE1, GE2, GE0) = GE0+(GE1*GE2)
MAT1 22 2.1e5   0.3 7.85e-9     1.0
ID Relationship identification number. ID must be unique with respect to other DVMREL2 cards.
No default (Integer > 0)
TYPE Material type to be related (MAT1, MAT2, MAT4, MAT5, MAT8, MAT9, or MAT9OR).
No default (Character)
MID Material identification number.
MPNAME/FID Material property name, such as "E" or "RHO" (as in the documentation of the material Bulk Data Entries), or field number on a material Bulk Data Entry.
No default (Character or Integer > 0)
EQID Equation ID of DEQATN data.
DESVAR Indicates DESVAR ID numbers follow.
DVID# DESVAR ID.
DTABLE Indicates DTABLE labels follow.
LABL# Constant label. Must match with a constant label of a DTABLE entry.
  1. See the DVMREL - Types section for details on the supported material fields and the MPNAME/FID entries.
