EDGEBH
Bulk Data Entry Defines geometry and restraining force per unit length for an edge blank holder in a one-step stamping simulation.
EDGEBH EID S1 T2 S2 T2 BFORCE BSID
EDGEBH 6 -1.0 1.0 1.0 1.0 100.0 5
EID Element identification number.
No default (Integer > 0)
S1, T1 Parametric entry points for the line.
No default (Real; | S1, T1 | ≤ 1.0)
S2, T2 Parametric exit points for the line.
No default (Real; | S2, T2 | ≤ 1.0)
BFORCE Blank holder restraining force.
No default (Real)
BSID Blank holder set identifier for retrieving the input file back to HyperForm. Not used by the solver.
  1. This entry is only valid with an @ HyperForm statement in the first line of the input file.
