EDRAWB
Bulk Data Entry Defines location and restraining force per unit length for a draw bead in a one-step stamping simulation.
EDRAWB | EID | S1 | T2 | S2 | T2 | DFORCE | DSID |
EDRAWB | 13 | -1.0 | 1.0 | 1.0 | -1.0 | 100.0 | 2 |
EID | Element identification number. No default (Integer > 0) |
S1, T1 | Parametric entry points for the line. No default (Real; | S1, T1 | ≤ 1.0) |
S2, T2 | Parametric exit points for the line. No default (Real; | S2, T2 | ≤ 1.0) |
DFORCE | Draw
bead restraining force per unit length. No default (Real) |
DSID | Draw
bead set identifier for retrieving the input file
back to HyperForm. Not
used by the solver. No default (Integer > 0) |
- This entry is only valid with an @ HyperForm statement in the first line of the input file.
