EIGRD
Bulk Data Entry Defines data required to perform eigenvalue extraction using the Lapack-based dense solver.
EIGRD | SID | V1 | V2 | ND | NORM |
EIGRD | 0.1 | 3.2 | 10 |
SID | Unique set identification number. No default (Integer > 0) |
V1,V2 | For
vibration analysis: Frequency range of
interest. Default = blank (V1 < V2, Real, or blank) |
ND | Number of roots desired. No default (Integer > 0 or blank) |
NORM | Method used for eigenvector normalization.
Default = MASS for normal modes analysis |
- For CMS residual runs, EIGRD is suitable for models with 20,000 degrees of freedom or lower.
