EL2PROP
Bulk Data Entry Used to assign property ID to elements in DMIG.
EL2PROP | ID | ||||||||
ELSETID | PTYPE | PROPID | ELSETID | PTYPE | PROPID | ||||
etc |
EL2PROP | 7 | ||||||||
8 | PSHELL | 3 |
ID | Identification number of
EL2PROP. No default (Integer > 0) |
ELSETID | Element set identification
number. No default (Integer > 0) |
PTYPE | Property type.
No default |
PROPID | Property identification
- This EL2PROP Bulk Data Entry can be used to assign Property ID's' to Element sets.
- The ID field is only used by HyperMesh. When ECHO entry is present in the model, all EL2PROP entries will be combined into one EL2PROP entry with an internally generated ID. The ID of the EL2PROP entries are not used in OptiStruct.
