ESLTADD
Bulk Data Entry Defines a combined time step selection set as a union of selected time steps defined via ESLTIME entries for Geometric Nonlinear ESLM optimization or a Multibody Dynamics ESLM optimization.
ESLTADD SID S1 S2 S3 S4 S5 S6 S7
  S8 S9 etc.
ESLTADD 101 9 11 13
SID Set identification number.
(Integer > 0)
Si Set identification numbers of time step selections defined via ESLTIME Bulk Data Entries. Si should be unique and may not be the identification number of a set defined by another ESLTADD entry.
(Integer > 0)
  1. ESLTADD can be selected within the Subcase Information section using the command ESLTIME=SID.
  2. ESLTADD entries take precedence over ESLTIME entries. If both entries have the same SID, only the ESLTADD entry will be used.
  3. This card is represented as a load collector in HyperMesh.
