.#.#.fat file
The .#.#.fat file is an ASCII format result file.
File Creation
This file is created for fatigue analysis and optimization.
File Contents
This file contains the average fatigue life/damage, top five damaged elements, and the detailed damage information (contribution from each static loadcase).
- The first # in the file name is the iteration number.
- The second # in the file name is the user-defined fatigue subcase ID.
- If a fatigue optimization is performed, this file is created for each fatigue subcase at the first and last iterations.
