FATMCRV
Bulk Data Entry Specifies the corresponding quantities (Ti) vs SN curve table ID’s via TABLEXN entries (TIDi).
FATMCRV | TID | QTYPE | TYPE | ||||||
T1 | TID1 | T2 | TID2 | T3 | etc |
FATMCRV | 101 | SM | SN | ||||||
150.0 | 10 | 175.0 | 20 | ENDT |
TID | Table identification
number. (Integer > 0) |
QTYPE | Weld type.
No default |
TYPE | Fatigue analysis
type.
No default |
Ti | Quantity values of the
type defined via the QTYPE field. No default (Real) |
TIDi | Table identification
numbers of TABLEXN entries which identify the
Fatigue curves. The nature of the Fatigue curves is defined via
the TYPE field. No default (Integer > 0) |
- TIDi must be unique with respect to all FATMCRV and TABLEXN table identification numbers.
- Quantity values must be listed in ascending order.
- The end of the table is indicated by the existence of ENDT in either of the two fields following the last entry. An error is detected if any continuations follow the entry containing the end-of-table flag ENDT.
- This table can be referenced by the MCRV_ID field of the MATFAT entry.
