FATPARM
Subcase Information Entry The FATPARM command can be used to select a FATPARM Bulk Data Entry that will define the parameters to be used for a Fatigue Analysis.
FATPARM = option
Argument | Options | Description |
option | <SID> No default |
- FATPARM Bulk Data Entries will not be used unless selected in the Subcase Information section.
- If present above the first subcase, it is applied to all fatigue analysis subcases.
