FATSEQ
Subcase Information Entry The FATSEQ command can be used to indicate that a subcase is a fatigue analysis subcase and to select a FATSEQ Bulk Data Entry that will define the loading sequence for the Fatigue Analysis.
FATSEQ = option
Argument Options Description
option <SID>
No default
SID
Set identification of a FATSEQ Bulk Data Entry.
  1. This command may not appear above the first subcase.
