FLDATA
Bulk Data Entry Defines a forming limit curve as a table of minor and major strain values in a one-step stamping simulation.
FLDATA | FLDID | Ei1 | Ei2 |
FLDATA | 2 | -.194 | .284 | ||||||
FLDATA | 2 | -.0.89 | .269 | ||||||
FLDATA | 2 | etc | etc | ||||||
FLDATA | 2 | .319 | .319 |
FLDID | Blank holder
identification number No default (Integer > 0) |
Ei1 | Minor strain
value No default (Real) |
Ei2 | Major strain
- This entry is only valid with an @ HyperForm statement in the first line of the input file.
