FORMAT
I/O Options EntryUsed to indicate the format in which results are to be output.
FORMAT = option
Argument | Options | Description |
option | <ASCII, OS, OPTI, HM, HYPER, BOTH, H3D, FLX, NASTRAN, PUNCH, PATRAN, APATRAN, O2, OUT2, OUTPUT2, PLOT,HDF5, KPI, NONE> |
- Information provided on OUTPUT entries take precedence over information provided on FORMAT entries. If neither of these entries are defined, the output formats defined in the Configuration File are used. If a format is not defined by the Configuration File, then both the HM and H3D formats are active by default.
- Multiple FORMAT commands are allowed.
- It is recommended to use the OUTPUT command instead of the FORMAT command since it is more flexible and allows different frequencies of output for different formats during an optimization.
- The HDF5 output is printed to a
.h5 binary results file. The current support of HDF5
output format is:
- In case of Linear Static and Normal
Modes analysis,
- The supported element types for element-based results (in
.h5 format) are:
Result Elements Supported FORCE/ELFORCE CBAR, CBEAM, CONROD, CTRIA3, CTRIA6, CQUAD4, CQUAD8 STRESS CROD, CBAR, CBEAM, CONROD, CELAS1, CELAS2, CBUSH, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CTETRA, CHEXA, CPENTA STRAIN - Corner results are also available for the above results with CQUAD4 and CQUAD8 elements.
.h5 format) are:
- In case of Nonlinear Static
analysis,
- The supported element types for STRESS and
STRAIN results (in .h5
format) are:
Result Elements Supported STRESS, STRAIN
CROD, CELAS1, CBAR, CBEAM, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CHEXA, CPENTA, CTETRA - Corner results are also available for CQUAD4 and CQUAD8.
- DISPLACEMENT, STRESS and STRAIN results are also available on-the-fly during the analysis, if the NLOUT entry is defined in the subcase.
format) are:
- In case of Linear Buckling analysis, only DISPLACEMENT result is available in .h5 format.
Modes analysis,
- KPI output includes maximum value for Displacement, Stress, Strain, and Plastic Strain with respect to the corresponding property. It is supported for linear and nonlinear static analysis only. Stresses and Strains are supported only for shells and solids. This output can also be activated from the corresponding I/O Options Entry (DISPLACEMENT, etc).
