CKGPDIR |
<WARN,
1, ERR, 2,
NO, 0, REV,
or 3> Default = ERR
- WARN or 1
- Same as ERR or 2 with
the exception that only warnings are issued.
- ERR or 2
- All non-zero length gap elements that have a prescribed
coordinate system are checked for misalignment of the
gap prescribed axis (x-axis of the prescribed coordinate
system) with the vector GA->B. Angles larger than 30
degrees produce warnings, angles larger than 60 degrees
produce errors.
- NO or 0
- No gap CID direction checks are performed.
- REV or 3
- The orientations of the vector GA->B that are generally
opposite to the prescribed axis are also accepted. The
tolerance levels are the same as for the default case,
except that they are measured from either 0 or 180
degrees reference angle.
