GRIDS
Bulk Data Entry Defines a grid point on the y-z plane, using cartesian coordinates, for use in the definition of arbitrary beam cross-sections.
GRIDS | ID | Y | Z |
GRIDS | 101 | 1.1 | 2.1 |
ID | Identification
number. No default (Integer > 0) |
Y | Y
location of the grid point. No default (Real) |
Z | Z
