HISOUT
I/O Options and Subcase Information Entry The HISOUT command can be used in the I/O Options section to control the amount of data printed to the .hgdata file.
HISOUT = option
Argument Options Description
option <Integer < 32>
Default = 31
HISOUT value is equal to the sum of the desired options:
1
Design variable.
2
Objective function and maximum percent constraint violation.
4
All non-stress responses.
8
All DRESP2 responses.
16
All DRESP3 responses.
blank
No output to .hgdata file.
Example: If design variables and all DRESP2 responses are wanted, enter:
HISOUT= 9
  1. When a HISOUT command is not present, a value of 31 is assumed.
