Processing math: 100%
HYBDAMP
Bulk Data Entry Defines the application of modal damping to the residual structure in a Direct Transient or Frequency Response analysis.
HYBDAMP SID METHOD SDAMP KDAMP
HYBDAMP Keyword for applying modal damping on a direct analysis
SID Unique hybrid damping SID (Refer to HYBDAMP I/O Option).
METHOD EIGRL/EIGRA data identification number. Hybrid damping is applied on the modes determined by the eigenvalue analysis.
No default (Integer > 0)
SDAMP A TABDMP1 entry identification number for modal damping.
KDAMP
-1/YES
Modal damping is entered into the complex stiffness matrix as material damping, instead of viscous damping.
1/NO (Default)
Enter the damping as viscous damping.
(Integer)
  1. HYBDAMP/SID can be set by the HYBDAMP I/O Options Entry in the I/O section of the input data.
  2. Hybrid damping can be defined as:
    If KDAMP is set to 1/NO (Default), then:(1)
    BH=[M][ϕ1ϕ2ϕn][b(ω1)b(ω2)b(ωn)][ϕT1ϕT2ϕTn][M]
    If KDAMP is set to -1/YES, then:(2)
    KH=[M][ϕ1ϕ2ϕn][g(ω1)g(ω2)g(ωn)][ϕT1ϕT2ϕTn][M]
    Where,
    ϕ i
    Modes of the structure
    [M]
    Structural mass matrix
    b( ω i)
    Modal damping values (b( ω i) = g( ω i) ω imi)
    b( ω i)
    Are equal to twice the critical damping ratios calculated from the TABDMP1 entry
    ω i
    Natural frequency of mode ϕ i
    mi
    Generalized mass of mode ϕ i
