IMPERF
Subcase Information Entry Defines the initial geometrical imperfection in nonlinear analysis.
IMPERF = option
Argument | Options | Description |
option | <SID> No default |
- IMPERF Bulk Data Entry will not be used, unless selected in the Subcase Information section.
- IMPERF should only be selected by a nonlinear subcase, which is not continued from a preceding nonlinear subcase.
