INVELB
Bulk Data Entry Defines initial velocity in a multibody situation.
INVELB SID BID CID
  VX VY VZ WX WY WZ
INVELB 1 3
  1000.0
SID Load set identification number.
(Integer > 0)
BID Body identification number.
(Integer > 0)
CID Reference coordinate system. A CID of zero or blank references the basic coordinate system.
(Integer > 0)
VX, VY, VZ Translational velocities.
(Blank or Real)
WX, WY, WZ Rotational velocities.
(Blank or Real)
  1. Only one initial velocity per body can be defined in a load set.
  2. This card is represented as a load collector in HyperMesh.
