INVELJ
Bulk Data Entry Defines initial velocity of a joint in a multibody situation.
INVELJ SID JID JTYPE VT VR
INVELJ 1 3 REV   10.0
SID Load set identification number.
(Integer > 0)
JID Joint identification number.
(Integer > 0)
JTYPE Joint type.
REV
Revolute
CYL
Cylindrical
TRANS
Translational
No default
VT Translational velocity.
Real, when JTYPE = TRANS
VR Rotational velocity.
Real, when JTYPE = REV
  1. Only one initial velocity per joint can be defined in a load set.
  2. Initial velocities of joints defined by INVELJ will be overwritten by MOTNJ, MOTNJE, or MOTNJC.
