ISTSADD
Bulk Data Entry Defines initial stress condition for nonlinear quasi-static analysis as a union of INISTRS entries.
ISTSADD | ID | IS1 | IS2 | IS3 | IS4 | IS5 | IS6 | IS7 | |
IS8 | IS9 | etc. |
ISTSADD | 9 | 101 | 102 | 103 |
ID | Unique identification
number. No default (Integer > 0) |
IS(i) | Identification number
of INISTRS entries. The
IS(i) values must be unique. No default (Integer > 0) |
- ISTSADD and INISTRS should not have the same ID.
- The ISTSADD Bulk Data Entry is selected by the Subcase Information command INISTRS.
