.kpi file
An OptiStruct ASCII format results file.
File Creation
This file is created when KPI output is requested via OUTPUT, FORMAT, or corresponding I/O Options Entry.
File Contents
This file contains key performance indicators for displacements, stresses, and strains.
The following table format is used to print the key performance indicators information.
For Displacement
KPI:
$ITERATION = 0
$DISPLACEMENTS
$SUBCASE ID = 1
PID GID MAG GID X GID Y GID Z
- Name
- Contents
- ITERATION
- Iteration number of the Optimization run (for Analysis this is always 0)
- DISPLACEMENTS
- Indicates that Displacement KPI results are output
- SUBCASE ID #
- Subcase ID
- PID
- Property ID
- GID
- Grid ID
- MAG
- Displacement Magnitude
- X, Y, Z
- Displacements in X, Y, Z components for corresponding GID's
For Stress/Strain
KPI:
$ITERATION = 0
$ELEMENT STRESSES
$SUBCASE ID = 1
PID EID VON XX/XX_I YY/XX_2 ZZ/YY_1 XY/YY_2 YZ/YX_1 XZ/XY_2
$ITERATION = 0
$ELEMENT STRAINS
$SUBCASE ID = 1
- Name
- Contents
- ITERATION
- ELEMENT STRESSES/STRAINS
- Indicates that Stress/Strain KPI results are output
- SUBCASE ID #
- Subcase ID
- PID
- Property ID
- EID
- Element ID
- VON
- von Mises stresses/strains
- XX, YY, ZZ, XY, YZ, XZ
- Stress/strain components
