LATPRM, R2LRATIO
Bulk Data Entry R2LRATIO is used to set the minimum radius-to-length ratio for Beam Cleaning procedure in the Second Phase of Lattice Optimization.
Parameter | Values | Description |
R2LRATIO | Real ≥ 0.0 Default = 0.01 |
- If R2LRATIO is not specified in the input deck, then R2LRATIO is not used.
- If R2LRATIO and MINRAD are both specified in the input deck, the max(R2LRATIO, MINRAD) value is used for beam cleaning.
- If R2LRATIO is specified in the input deck without any value, then its default value is 0.01.
