LOADJG
Bulk Data Entry Defines loading for joint connector JOINTG Bulk Data Entry.
LOADJG ID   TID
  JID1 DOF VALUE
  JID2 DOF VALUE
  etc
LOADJG 3   3
  2 1 1.0
  3 4 2.0
ID Load set identification number.
(Integer > 0)
TID Identification number of a TABLEDi entry that defines loading scale factors vs time. The loads on the VALUE fields are multiplied with the scale factors to determine time-dependent loads on the joint degrees of freedom.
Default = blank (Integer > 0)
JIDi Identification number of a JOINTG Bulk Data Entry on which the loading is to be applied.
DOF Degree of freedom component number.
No default (Integer 1 through 6)
VALUE Load value to be applied on the identified degree of freedom for the specified JOINTG joint.
No default (Integer > 0)
  1. The types and directions of motion for the component numbers are:
    Component Number(s) Motion Type Motion Direction(s)
    1, 2, and 3 Displacement X,Y,Z
    4, 5, and 6 Rotation X,Y,Z
