LOADJG
Subcase Information Entry Used in the Subcase Information section to select a load set to be applied to joints which are defined via the JOINTG Bulk Data Entry.
LOADJG = option
Argument | Options | Description |
option | <SID> No default |
- Only one LOADJG entry can be present for each subcase.
- LOADJG is currently supported only for Axial, Inline, and Revolute joints.
