LOCATE
Subcase Information Entry The LOCATE entry can be used to select subcase-specific location (geometric position) of each part in the model.
LOCATE = SID
Argument | Options | Description |
SID | <SID> Integer > 0 No default |
- The LOCATE entry should only be defined within a subcase and cannot be specified above the first subcase.
- If the LOCATE Subcase Information Entry is utilized within a single subcase, then all subcases in the model should have LOCATE entries referring to their corresponding LOCATE Bulk Data Entries.
- LOCATE entries are only supported in Linear Static subcases.
- The LOCATE entry can be used in conjunction with the SUBMODEL entry.
