MARKER
Bulk Data Entry Define a marker by associating a grid and a coordinate system.
MARKER | MID1 | GID1 | CID1 | MID2 | GID2 | CID2 | |||
MID3 | GID3 | CID3 | etc | etc | etc |
MARKER | 3 | 345 | 123 |
MIDi | Marker identification
number. Each marker has a unique ID. The marker gets its location from the grid corresponding to the GID and the orientation from the coordinate system (CID). (Integer > 0) |
GIDi | Grid identification
number. (Integer > 0) |
CIDi | Coordinate system
identification number. (Integer ≥ 0 or blank) Default (Blank, defaults to basic coordinate system) |
- Multiple markers can be located at the same grid with the same or with a different CID.
- This card is represented as a sensor in HyperMesh.
