Loading [MathJax]/jax/output/CommonHTML/jax.js
MAT1
Bulk Data Entry Defines the material properties for linear, temperature-independent, and isotropic materials.
MAT1 MID E G NU RHO A TREF GE
  ST SC SS
MAT1 17 3.+7   0.33 4.28
MID Unique material identification.
Integer
Specifies an identification number for this material.
<String>
Specifies a user-defined string label for this material entry. 2
No default (Integer > 0 or <String>)
E Young's modulus.
Default = blank (Real or blank)
G Shear modulus.
NU Poisson's ratio.
If < 0.0, a warning is issued.
Default = blank (-1.0 < Real < 0.5 or blank)
RHO Mass density. Used to automatically compute mass for all structural elements.
No default (Real)
A Thermal expansion coefficient.
No default (Real)
TREF Reference temperature for thermal loading.
Default = 0.0 (Real)
GE Structural element damping coefficient. 10 11
No default (Real)
ST, SC, SS Stress limits in tension, compression and shear. Used for composite ply failure calculations.
No default (Real)
  1. The material identification number/string must be unique for all MAT1, MAT2, MAT8 and MAT9 entries.
  2. String based labels allow for easier visual identification of materials, including when being referenced by other cards. (example, the MID field of properties). For more details, refer to String Label Based Input File in the Bulk Data Input File.
  3. Either E or G must be specified (that is, non-blank).
  4. If any one of E, G, or NU is blank, it is computed to satisfy the identity,
    E = 2(1+NU)G; otherwise, values supplied by you are used.
  5. If E and NU are both blank, they are both given the value 0.0.
  6. If G and NU are both blank, they are both given the value 0.0.
  7. Unlikely data on one or more MAT1 entries result in a warning message. Unlikely data is defined as:
    • E < 0.0 or
    • G < 0.0 or
    • NU > 0.5 or
    • NU < -1.0 or
    • |1E2(1+NU)G|>0.01
    • except for cases covered by comments 5 and 6.
  8. It is strongly recommended that only two of the three values E, G, and NU be input.
  9. The large field format may also be used.
  10. To obtain the damping coefficient GE, multiply the critical damping ratio, C/C0 by 2.0.
  11. TREF and GE are ignored, if a MAT1 entry is referenced by a PCOMP, PCOMPP, or PCOMPG Bulk Data Entries.
  12. This card is represented as a material in HyperMesh.
    Element Type E NU G
    CROD, CBAR, CBEAM, and CWELD Axial and Bending N/A Transverse Shear and Torsion
    CSHEAR N/A N/A Shear
    CQUAD and CTRIA Membrane and Bending Membrane and Bending Transverse Shear
    CHEX, CTETRA, CPENTA, CPRYRA and CSEAM Deformation N/A
