MAT2
Bulk Data Entry Defines the material properties for linear, temperature-independent, and anisotropic materials for two-dimensional elements.
MAT2 | MID | G11 | G12 | G13 | G22 | G23 | G33 | RHO | |
A1 | A2 | A12 | TREF | GE | ST | SC | SS |
MAT2 | 13 | 6.2+3 | 6.2+3 | 5.1+3 | 0.056 | ||||
6.5-6 | 6.5-6 | -500.0 |
MID | Unique material identification.
No default (Integer > 0 or <String>) |
Gij | Material property
matrix. No default (Real) |
RHO | Mass density. Used to
automatically compute mass for all structural elements. No default (Real) |
Ai | Thermal expansion
coefficient vector. No default (Real) |
TREF | Reference temperature for
the calculation of thermal loads. Data from the
MAT2 entry is used directly, without
adjustment of equivalent E, G,
or NU values. Default = blank (Real or blank) |
GE | Structural element damping
coefficient. 6
7 No default (Real) |
ST, SC, SS | Stress limits in tension,
compression and shear. Used for composite ply failure
calculations. No default (Real) |
- The material identification number/string must be unique for all MAT1, MAT2, MAT8 and MAT9 entries.
- String based labels allow for easier visual identification of materials, including when being referenced by other cards. (example, the MID field of properties). For more details, refer to String Label Based Input File in the Bulk Data Input File.
- The convention for the Gij
in fields 3 through 8 is represented by the matrix relationship:
(1) {σ1σ2τ12}=[G11G12G13G12G22G23G13G23G33] ({ε1ε2γ12}−(T−TO){A1A2A12}) - If this entry is referenced by the MID3 field (transverse shear) on the PSHELL, G13, G23, and G33 must be blank.
- The long field format may be used.
- To obtain the damping coefficient GE, multiply the critical damping ratio, C/C0 by 2.0.
- TREF and GE are ignored, if a MAT2 entry is referenced by a PCOMP entry.
- If a MAT2 card is pointed to by a MID4 on PSHELL, and has a material ID greater than 400,000,000, then the thermal membrane-bending coefficients A1, A2, and A12 have a modified interpretation, and represent [G]*[alpha], rather than [alpha]. Here, [G] is a matrix composed of G11, G22, through, G33. This is to maintain consistency with respective terms generated internally by the PCOMP card.
- This card is represented as a material in HyperMesh.
