Material Property Checks for MAT2
MAT2 only applied to 2D elements.
Material Requirements | MAT2 |
Mathematical | None |
Semi-stability | If any eigenvalues of [G]
< 0, an error termination will
occur. PARAM,CHECKMAT, NO will disable this error. |
Not all zeros | If all eigenvalues of [G]
= 0, an error termination will occur. If any eigenvalue of [G] = 0, a warning is provided. |
Consistency | none |
Mathematical for composites | After homogenization, if Det[G] = 0, an error termination will occur. |
