Material Property Checks for MAT9
MAT9 only applies to 3D elements.
Material Requirements | MAT9 |
Mathematical | none |
Semi-stability | If any eigenvalues of [G]
< 0, an error termination will occur. PARAM ,CHECKMAT,NO will disable this error. |
Not all zeros | If all eigenvalues of [G]
= 0, an error termination will occur. If any eigenvalue of [G] = 0, a warning is provided. |
Consistency | none |
