MATHF
Bulk Data Entry Defines the material properties in a one-step stamping simulation.
MATHF MID E NU Y K n EPS0
  R0 R45 R90 TABLEID
MATHF 17 21.0E4 0.3 184.297 549.03 0.22 0.007
  1.6 1.6 1.6
MID Unique material identification number.
No default (Integer > 0)
E Young's Modulus.
No default (Real)
NU Poisson's ratio.
Default = blank (-1.0 < Real < 0.5 or blank)
Y Yield stress.
No default (Real)
K Strength coefficient.
No default (Real or blank)
n Strain hardening component.
EPS0 Pre-strain coefficient.
R0, R45, R90 Lankford coefficients.
No default (Real)
TABLEID Table ID for stress-strain curve using a TABLES1 entry.
  1. This entry is only valid with a @ HyperForm statement in the first line of the input file.
  2. The TABLEID and the corresponding curve are required only when material data is specified with a stress-strain curve. For such case, material parameter such as K, n and EPS0 are extracted from the stress strain curve.
