MATT2
Bulk Data Entry Specifies temperature-dependent material properties on MAT2 entry fields via TABLEMi or TABLEG entry.
MATT2 MID T(G11) T(G12) T(G13) T(G22) T(G23) T(G33) T(RHO)
  T(A1) T(A2) T(A3)   T(GE) T(ST) T(SC) T(SS)
MATT2 17 32         15
  62
MID Material property identification number that matches the identification number on a MAT2 entry.
(Integer > 0)
T(Gij) Identification number of a TABLEMk or TABLEG entry for the terms in the material property matrix.
(Integer ≥ 0 or blank)
T(RHO) Identification number of a TABLEMk or TABLEG entry for the mass density.
T(Ai) Identification number of a TABLEMk or TABLEG entry for the thermal expansion coefficient.
(Integer or blank)
T(GE) Identification number of a TABLEMk or TABLEG entry for the damping coefficient.
T(ST) Identification number of a TABLEMk or TABLEG entry for the tension stress limit.
T(SC) Identification number of a TABLEMk or TABLEG entry for the compression limit.
T(SS) Identification number of a TABLEMk or TABLEG entry for the shear limit.
  1. Fields 3, 4, and so on of this entry correspond, field-by-field, to fields 3, 4, and so on of the MAT2 entry referenced in field 2.The value in a particular field of the MAT2 entry is replaced (if TABLEM1 or TABLEG is used) or modified (if TABLEM2/3/4 is used) by the table referenced in the corresponding field of this entry. In the example shown, G11 is modified by TABLEMk 32; G33 is modified by TABLEMk 15; and A1 is modified by TABLEMk 62. If Ri is zero or blank, there is no temperature dependence of the field on the MAT2 entry.
  2. The MATT2 entries may refer to blank entries on the respective MAT2 card. In which case, they will be applied to default values of respective parameters.
  3. The TEMPERATURE Subcase Information Entry (with type=MATERIAL) is required to activate temperature-dependent material behavior and to define the temperature field (option = SID of TEMP, TEMPD or the SUBCASE ID of a thermal analysis subcase).
  4. With TABLEM1 or TABLEG, the respective field on MAT2 will be replaced by the table data on MATT2. With TABLEM2/3/4, the respective field of MAT2 will be modified by the table data.
  5. This card is represented as a material in HyperMesh.
