MATT9
Bulk Data Entry Specifies temperature-dependent material properties on MAT9 entry fields via TABLEMk or TABLEG entry.
MATT9 | MID | T(G11) | T(G12) | T(G13) | T(G14) | T(G15) | T(G16) | T(G22) | |
T(G23) | T(G24) | T(G25) | T(G26) | T(G33) | T(G34) | T(G35) | T(G36) | ||
T(G44) | T(G45) | T(G46) | T(G55) | T(G56) | T(G66) | T(RHO) | T(A1) | ||
T(A2) | T(A3) | T(A4) | T(A5) | T(A6) | T(GE) |
MATT9 | 17 | 32 | 18 | 17 | |||||
12 | |||||||||
5 | 10 |
MID | Material property identification number that
matches the identification number on a
MAT9 entry. (Integer > 0) |
T(Gij) | Identification number of a TABLEMk or TABLEG
entry for the terms in the material property matrix. (Integer ≥ 0 or blank) |
T(RHO) | Identification number of a TABLEMk or TABLEG
entry for the mass density. (Integer ≥ 0 or blank) |
T(Ai) | Identification number of a TABLEMk or TABLEG
entry for the thermal expansion coefficients. (Integer ≥ 0 or blank) |
T(GE) | Identification number of a TABLEMk or TABLEG
entry for the damping coefficient. (Integer ≥ 0 or blank) |
- Fields 3, 4, and so on of this entry correspond, field-by-field, to fields 3, 4, and so on of the MAT9 entry referenced in field 2. The value recorded in a particular field of the MAT9 entry is replaced (if TABLEM1 or TABLEG is used) or modified (TABLEM2/3/4 is used) by the table referenced in the corresponding field of this entry. In the example shown, G11 is modified by TABLEMj 32; G14 is modified by TABLEMj 18, and so on. If the fields are zero or blank, there is no temperature dependence of the field on the MAT9 entry.
- The MATT9 entries may refer to blank entries on the respective MAT9 card. In which case, they will be applied to default values of respective parameters.
- The continuation entries are optional.
- The TEMPERATURE Subcase Information Entry (with type = MATERIAL) is required to activate temperature-dependent material behavior and to define the temperature field (option = SID of TEMP, TEMPD or the SUBCASE ID of a thermal analysis subcase).
- With TABLEM1 or TABLEG, the respective field on MAT9 will be replaced by the table data on MATT9. With TABLEM2/3/4, the respective field of MAT9 will be modified by the table data.
- This card is represented as a material in HyperMesh.
