MATTVP
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MATVP Bulk Data Entry fields via TABLEMi or TABLEG entries.
MATTVP MID   T(A) T(n) T(m)
MATTVP 2   200 201 202
MID Material identification number of a MATTVP Bulk Data Entry that is temperature dependent.
No default (Integer > 0)
T(A) A TABLEMi or TABLEG entry identification number for the parameter A.
(Integer ≥ 0 or blank)
T(n) A TABLEMi or TABLEG entry identification number for the parameter n.
T(m) A TABLEMi or TABLEG entry identification number for the parameter m.
  1. The value in a particular field of the MATVP entry is replaced (if TABLEM1 or TABLEG is used) or modified (if TABLEM2/3/4 is used) by the table referenced in the corresponding field of this entry.
  2. If the fields are blank or zero, then constant properties defined on the MATVP Bulk Data card are used.
