MATVE
Bulk Data Entry Defines material properties for nonlinear viscoelastic materials.
Format A: Prony Series (Model = PRONY)
MATVE MID Model     gD1 tD1 gB1 tB1
  gD2 tD2 gD3 tD3 gD4 tD4 gD5 tD5
  gB2 tB2 gB3 tB3 gB4 tB4 gB5 tB5
Format B: Bergström-Boyce (Model = BBOYCE)
MATVE MID Model   Sb A C m E
Example A: Prony Series (Model = PRONY)
MATVE 2 PRONY     0.25 5e-2 0.25 5e-2
Example B: Bergström-Boyce (Model = BBOYCE)
MATVE 2 BBOYCE   2.0 0.1 -0.7 5.0 0.01
MID Unique material identification number.
No default (Integer > 0)
Model Viscoelastic material model type.
PRONY (Default)
Linear viscoelastic model based on Prony series.
BBOYCE
Bergström-Boyce model.
gDi Modulus ratio for the i MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGPbaaaa@39C5@ -th deviatoric Prony series.
Default = Blank (Real > 0.0)
tDi Relaxation time for the i MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGPbaaaa@39C5@ -th deviatoric Prony series.
gBi Modulus ratio for the i MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGPbaaaa@39C5@ -th bulk Prony series.
tBi Relaxation time for the i MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGPbaaaa@39C5@ -th bulk Prony series.
Sb Stress scaling factor that defines the ratio of the stress carried by network B to that carried by network A under identical elastic stretching. 7
No default (Real > 0.0)
A Effective creep strain rate. 7
C Negative exponent characterizes the creep strain dependence of the effective creep strain rate in network B. 7
No default (-1.0 ≤ Real ≤ 0.0)
m Positive exponent characterizes the effective stress dependence of the effective creep strain rate in network B. 7
No default (Real ≥1.0)
E Material parameter to regularize the creep strain rate in the vicinity of the undeformed state. 7
Default = 0.01 (Real ≥0.0)
  1. The CHEXA, CTETRA, CPENTA, and CPYRA elements are currently supported.
  2. The instantaneous response can be provided by MAT1, MAT9 or MATHE entries, which should have the same MID as the MATVE entry.
  3. The linear viscoelastic material (Model = PRONY) is represented by the generalized Maxwell model. The material response is given by the following convolution representation.(1)
    σ=0tg(ts)σ˙0ds MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4WdmNaeyypa0Zaa8qmaeaacaWGNbWaaeWaaeaacaWG0bGaeyOeI0Iaam4CaaGaayjkaiaawMcaaiqbeo8aZzaacaWaaSbaaSqaaiaaicdaaeqaaOGaamizaiaadohaaSqaaiaaicdaaeaacaWG0baaniabgUIiYdaaaa@468B@
    Where,
    g(t)=γ+iγietτi MathType@MTEF@5@5@+=feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zamaabmaabaGaamiDaaGaayjkaiaawMcaaiabg2da9iabeo7aNnaaBaaaleaacqGHEisPaeqaaOGaey4kaSYaaabuaeaacqaHZoWzdaWgaaWcbaGaamyAaaqabaGccaWGLbWaaWbaaSqabeaacqGHsisldaWcaaqaaiaadshaaeaacqaHepaDdaWgaaadbaGaamyAaaqabaaaaaaaaSqaaiaadMgaaeqaniabggHiLdaaaa@4A64@
    The subscript i MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGPbaaaa@39C5@ indicates the i MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGPbaaaa@39C5@ -th component in the Prony series. A maximum of 5 components are allowed.
    γi
    Modulus ratio
    τi
    Relaxation time
    σ0 MathType@MTEF@5@5@+=feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaSbaaSqaaiaaicdaaeqaaaaa@38A0@
    Instantaneous stress response
  4. For the isotropic model, the deviatoric and bulk responses can be specified separately. For the anisotropic model, only gDi and tDi are used and the bulk specifications are ignored.
  5. The material relaxation response is controlled by the card VISCO. For example, if the user wants to simulate a physical relaxation test, the first subcase can omit the VISCO card so that material response is only the instantaneous elasticity in this subcase. In the next subcase, the user can add a VISCO card so that the material response is viscoelastic.
  6. For Implicit Nonlinear Analysis, MATVE is supported for small displacement and large displacement nonlinear analysis.
  7. The nonlinear viscoelastic material (Model = BBOYCE) is supported only for solid elements in Nonlinear Explicit Analysis.
    The response of the material can be represented using an equilibrium hyperelastic network A, and a time-dependent hyperelastic - nonlinear viscoelastic network B. The Hyperelastic material models for network A and B can be selected from existing MATHE card.
    The deformation gradient tensor, F MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraaaa@36C1@ is assumed to act on both networks and is decomposed into elastic ( FBe MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaDaaaleaacaWGcbaabaGaamyzaaaaaaa@389F@ ) and inelastic ( FBcr MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaDaaaleaacaWGcbaabaGaam4yaiaadkhaaaaaaa@3994@ ) parts in network B as:(2)
    F=FA=FBe.FBcr MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiabg2da9iaadAeadaWgaaWcbaGaamyqaaqabaGccqGH9aqpcaWGgbWaa0baaSqaaiaadkeaaeaacaWGLbaaaOGaaiOlaiaadAeadaqhaaWcbaGaamOqaaqaaiaadogacaWGYbaaaaaa@4197@
    The evolution of inelastic deformation gradient on network B is governed by:(3)
    FBe.F˙Bcr.FBcr1.FBe1=ε˙BvSBσ¯B MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaDaaaleaacaWGcbaabaGaamyzaaaakiaac6caceWGgbGbaiaadaqhaaWcbaGaamOqaaqaaiaadogacaWGYbaaaOGaaiOlaiaadAeadaqhaaWcbaGaamOqaaqaaiaadogacaWGYbGaeyOeI0IaaGymaaaakiaac6cacaWGgbWaa0baaSqaaiaadkeaaeaacaWGLbGaeyOeI0IaaGymaaaakiabg2da9iqbew7aLzaacaWaa0baaSqaaiaadkeaaeaacaWG2baaaOWaaSaaaeaacaWGtbWaaSbaaSqaaiaadkeaaeqaaaGcbaGafq4WdmNbaebadaWgaaWcbaGaamOqaaqabaaaaaaa@517D@
    The Bergström-Boyce hardening formulation is given by:(4)
    ε˙Bv=A(λ˜1+E)cσ¯Bm MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafqyTduMbaiaadaqhaaWcbaGaamOqaaqaaiaadAhaaaGccqGH9aqpcaWGbbGaaiikaiqbeU7aSzaaiaGaeyOeI0IaaGymaiabgUcaRiaadweacaGGPaWaaWbaaSqabeaacaWGJbaaaOGafq4WdmNbaebadaqhaaWcbaGaamOqaaqa aiaad2gaaaaaaa@46BB@
    Where,
    σ¯B=SB:SB MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4WdmNbaebadaWgaaWcbaGaamOqaaqabaGccqGH9aqpdaGcaaqaaiaadofadaWgaaWcbaGaamOqaaqabaGccaGG6aGaam4uamaaBaaaleaacaWGcbaabe aaaeqaaaaa@3E42@
    λ˜=13I:(FBcr.(FBcr)T) MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafq4UdWMbaGaacqGH9aqpdaGcaaqaamaalaaabaGaaGymaaqaaiaaiodaaaGaamysaiaacQdadaqadaqaaiaadAeadaqhaaWcbaGaamOqaaqaaiaadogacaWGYbaaaOGaaiOlamaabmaabaGaamOramaaDaaaleaacaWGcbaabaGaam4yaiaadkhaaaaakiaawIcacaGLPaaadaahaaWcbeqaaiaadsfaaaaakiaawIcacaGLPaaaaSqabaaaaa@4812@
    SB MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uamaaBaaaleaacaWGcbaabeaaaaa@37C1@
    Deviatoric part of the Cauchy stress tensor in network B.
    Inelastic deformation gradient tensor in network B.
