Processing math: 100%
MATX25
Bulk Data Entry Defines an elasto-plastic orthotropic material with Tsai-Wu and CRASURVT yield criteria for composite shell materials.
MATX25 MID EPSF1 EPSF2 EPST1 EPSM1 EPST2 EPSM2 DTENDS
  WPMAX WPREF I GAMINI GAMMAX DMAX RATIO
  FSMOOTH F I
Continuation line for I = TSAI
  B N FMAX
  SY1T SY2T SY1C SY2C ALFA
  SY12C SY12T C12 EPSR0 ICC
Continuation line for I = CRAS
  C EPSR0 ALFA ICCG
  SY1T B1T N1T SMAX1T C1T
  EPS1T1 EPS2T1 SRST1 WMPT1
  SY2T B2T N2T SMAX2T C2T
  EPS1T2 EPS2T2 SRST2 WMPT2
  SY1C B1C N1C SMAX1C C1C
  EPS1C1 EPS2C1 SRSC1 WMPC1
  SY2C B2C N2C SMAX2C C2C
  EPS1C2 EPS2C2 SRSC2 WMPC2
  SY12T B12T N12T SMAX12T C12T
  EPS1T12 EPS2T12 SRST12 WMPT12
MAT8 102 70000 70000 0.3 26923.1 26923.1 26923.1
MATX25 102     0.15 0.2     0.95
      2
  0.2 1.0 2.0
  1E10 1E10 1E10 1E10
  1E10 1E10
MID Material ID of the associated MAT8. 1
No default (Integer > 0)
EPSF1 Total tensile failure in direction 1.
Default = 1E30 (Real)
EPSF2 Total tensile failure in direction 2.
EPST1 Tensile failure strain in direction 1.
(Real)
EPSM1 Maximum strain in direction 1.
(Real)
EPST2 Tensile failure strain in direction 2.
(Real)
EPSM2 Maximum strain in direction 2.
(Real)
DTENDS Maximum damage of composite tensile strength.
Default = 0.999 (Real < 1.0)
WPMAX Maximum plastic work.
WPREF Reference plastic work.
Default = 1.0 (Real)
I Total element failure criteria.
=0
Shell is deleted if Wp* > Wp*max for 1 layer
=1
Shell is deleted if Wp* > Wp*max for all layers
=2
If for each layer, Wp* > Wp*max or tensile failure in direction 1(t1)
=3
If for each layer, Wp* > Wp*max or tensile failure in direction 2(t2)
=4
If for each layer, Wp* > Wp*max or tensile failure in directions 1(t1) and 2(t2)
=5
If for all layers: Wp* > Wp*max or tensile failure in direction 1(t1) or if for all layers: Wp* > Wp*max or tensile failure in direction 2(t2)
=6
If for each layer, Wp* > Wp*max or tensile failure in direction 1(t1) or 2(t2)
Default = 0 (Integer)
GAMINI Delamination shear strain. 11
GAMMAX Maximum shear strain.
Default = 1.1E30 (Real)
DMAX Maximum damage.
RATIO Ratio parameter control to delete shell elements.
< 0.0
The element will be deleted if all of the layers but one fail (the number of layers that did not fail is equal to 1).
> 0.0
The element will be deleted if: numberoffailedlayersnumberoftotallayersratio
FSMOOTH Strain rate smoothing flag.
OFF (Default)
ON
F Cutoff frequency for strain rate filtering.
I Formulation flag.
TSAI (Default)
CRAS
I=TSAI
B Hardening parameter.
(Real)
N Hardening exponent.
FMAX Maximum value of yield function.
SY1T Tension in direction 1.
(Real > 0)
SY2T Tension in direction 2.
(Real > 0)
SY1C Compression yield stress in direction 1.
(Real > 0)
SY2C Compression yield stress in direction 2.
(Real > 0)
ALFA F12 reduction factor.
SY12C Compression yield stress in direction 12.
(Real > 0)
SY12T Tension yield stress in direction 12.
(Real > 0)
C12 Strain rate coefficient.
=0.0
No strain rate dependency.
(Real)
EPSR0 Reference strain rate.
(Real)
ICC Yield stress in shear and strain rate flag. 9
=0
Default, set to 1
=1
Strain rate effect on FMAX no effect on WPMAX
=2
No strain rate effect on FMAX and WPMAX
=3
Strain rate effect on FMAX and WPMAX
=4
No strain rate effect on FMAX effect on WPMAX
(Integer)
I=CRAS
C Global strain rate coefficient for plastic work criteria.
(Real)
(Real)
Default= 1.0 (Real)
ICCG Global composite plasticity parameters flag for strain rate computation: 9
=1 (Default)
Strain rate effect on SMAX1T, SMAX2T, SMAX1C, SMAX2C, SMAX12T; no strain rate effect on WPMAX.
=2
No strain rate effect on SMAX1T, SMAX2T, SMAX1C, SMAX2C, SMAX12T; no strain rate effect on WPMAX.
=3
Strain rate effect on SMAX1T, SMAX2T, SMAX1C, SMAX2C, SMAX12T and strain rate effect on WPMAX.
=4
No strain rate effect on SMAX1T, SMAX2T, SMAX1C, SMAX2C, SMAX12T and strain rate effect on WPMAX.
(Integer)
SY1T Tension yield stress in direction 1.
(Real > 0)
B1T Hardening parameter in direction 1.
(Real)
N1T Hardening exponent in direction 1.
SMAX1T Maximum stress in direction 1.
C1T Strain rate coefficient in direction 1.
=0
Default = C (Real)
EPS1T1 Initial softening strain in direction 1.
EPS2T1 Maximum softening strain in direction 1.
Default = 1.2 * EPS1T1 (Real)
SRST1 Residual stress in direction 1.
Default = 10E-3*SY1T (Real)
WMPT1 Maximum plastic work in tension direction 1.
SY2T Tension yield stress in direction 2.
(Real > 0)
B2T Hardening parameter in direction 2.
Default = B1T (Real)
N2T Hardening exponent in direction 2.
Default = N1T (Real)
SMAX2T Maximum stress in direction 2.
C2T Strain rate coefficient in direction 2.
=0
Default = C (Real)
EPS1T2 Initial softening strain in direction 2.
EPS2T2 Maximum softening strain in direction 2.
Default = 1.2*EPS1T1 (Real)
SRST2 Residual stress in direction 2.
Default = 10E-3 * SY2T (Real)
WMPT2 Maximum plastic work in tension direction 2.
(Real > 0)
B1C Hardening parameter in direction 1.
Default = B2T (Real)
N1C Hardening exponent in direction 1.
Default = N2T (Real)
SMAX1C Maximum stress in direction 1.
C1C Strain rate coefficient in direction 1.
=0.0
Default = C (Real)
EPS1C1 Initial softening strain in direction 1.
ESP2C1 Maximum softening strain in direction 1.
Default = 1.2*EPS1C1 (Real)
SRSC1 Residual stress in direction 1.
Default = 10E-3*S1YC (Real)
WMPC1 Maximum plastic work in compression direction 1.
(Real > 0)
B2C Hardening parameter in direction 2.
Default = B1C (Real)
N2C Hardening exponent in direction 2
Default = N1C (Real)
SMAX2C Maximum stress in direction 2.
C2C Strain rate coefficient in direction 2.
=0.0
Default = C (Real)
EPS1C2 Initial softening strain in direction 2.
EPS2C2 Maximum softening strain in direction 2.
Default = 1.2*EPS1C2 (Real)
SRSC2 Residual stress in direction 2.
Default = 10E-3*S2YC (Real)
WMPC2 Maximum plastic work in compression direction 2.
(Real > 0)
B12T Hardening parameter in direction 12.
Default = B2C (Real)
N12T Hardening exponent in direction 12.
SMAX12T Maximum stress in direction 12.
C12T Strain rate coefficient in direction 12.
=0.0
Default = C (Real)
EPS1T12 Initial softening strain in direction 12.
EPS2T12 Maximum softening strain in direction 12.
Default = 1.2*EPS1T12 (Real)
SRST12 Residual stress in direction 12.
Default = 10E-3*SY12T (Real)
WMPT12 Maximum plastic work in shear.
  1. The material identification number must be that of an existing MAT8 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT8.
  2. MATX25 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS=EXPDYN. It is ignored for all other subcases.
  3. Tsai-Wu formula (I=TSAI) is not available with QEPH (I=24 on PCOMPX) shell elements, it is only available with Q4 (I=1, 2, 3, 4 on PCOMPX) and QBAT(I=12 on PCOMPX) shell elements.
  4. The Lamina yield surface for Tsai-Wu criteria (I=TSAI) is:(1)
    F=F1σ1+F2σ2+F11σ21+F22σ22+F44σ212+2F12σ1σ2F(WpWpref)
    Where,
    Wp
    Plastic work
    Wpref
    F(WpWpref)
    Yield envelope evolution
    Where,
    b
    hardening parameter for plastic work
    n
    hardening exponent
    F1=1σc1y+1σt1y;F2=1σc2y+1σt2yF11=1σc1yσt1y;F22=1σc2yσt2yF44=1σ212yσt12y;F12=α2F11F22
  5. The CRASURV model is an improved version of the former law based on the standard Tsai-Wu criteria. The main changes concern the expression of the yield surface before plastification and during work hardening. First, in a CRASURV model, the coefficient F44 depends only on one input parameter:(2)
    F44=1(σ12y)2
    Another modification concerns the parameters Fij which are expressed now in function of plastic work and plastic work rate:(3)
    F1(Wp)σ1+F2(Wp)σ2+F11(Wp)σ21+F22(Wp)σ22+F44(Wp)σ212+2F12(Wp)σ1σ2(1+bWnp)(1+cln˙ε˙ε0)
    (4)
    σc1y(Wp)=σc1y(1+bc1(W1cp)n)(1+cc1ln˙ε˙ε0)
    (5)
    σc2y(Wp)=σc2y(1+bc2(W2cp)n)(1+cc1ln˙ε˙ε0)
    (6)
    σt1y(Wp)=σt1y(1+bt1(W1tp)n)(1+ct1ln˙ε˙ε0)
    (7)
    σt2y(Wp)=σt2y(1+bt2(W2tp)n)(1+ct1ln˙ε˙ε0)
    σ12y(Wp)=σ12y(1+b12(W12p)n)(1+c12ln˙ε˙ε0)
  6. If the total tensile failure value EPSF1 is reached in the direction 1 and respectively ε EPSF2 in the direction 2, the stresses tensor in the layer is permanently reset to 0.
  7. If a shell has several layers with one material per layer (different materials, different I), the IOFF used is the one that is associated to the shell in the shell element definition.
  8. Both Wp* and Wp*max are defined as:(8)
    Wp*=WpWprefandWp*max=WpmaxWpref
  9. The plastic work criteria is:(9)
    WpWpref>WpmaxWpref(1+cln˙ε˙ε0)
    When ICC=2, 3, or 4 for Tsai-Wu formula, when ICCG=3 or 4 for CRASURV formula.
  10. Delamination is a global model:(10)
    σ31=G31(1d)γ31
    (11)
    σ23=G23(1d)γ23
    with d=γγiniγmaxγiniγmaxγ applies to the all shell and not independently per each layer.
  11. Thereby, the coefficients GAMINI, GAMMAX, and DMAX considered, are the coefficients which are defined in the global material associated to the shell equivalent out-of-plane shear strain.
  12. The I and RATIO field values are utilized only if they are defined in the material assigned to a part, these fields are not considered if they are only defined in material used for a layer in the property entry. This option is not available for solid elements.
  13. This card is represented as extension to a MAT8 material in HyperMesh.
