Processing math: 100%
MATX65
Bulk Data Entry Defines additional material properties for tabulated strain rate dependent elastic-plastic material for geometric nonlinear analysis.
MATX65 MID EPSMAX FSMOOTH F NLOAD
If NLOAD ≥ 1, NLOAD times
  TIDL TIDU EPSR FSCAL
MAT1 91 60.4   0.33 2.70E-06
MATX65 91 2.70E-06     1
  1 2
MID Material ID of the associated MAT1. 1
No default (Integer > 0)
EPSMAX Failure plastic strain ˙ε max.
(Real > 0)
FSMOOTH Strain rate filtering flag.
OFF (Default)
ON
F Cutoff frequency for strain rate filtering.
Default = 1.E30 (Real ≥ 0)
NLOAD Number of loading/unloading stress-strain function pairs.
Default = 0 (Integer > 0)
TIDL Identification number of TABLES1 entry that defines the loading stress-strain function.
(Integer > 0)
TIDU Identification number of TABLES1 entry that defines the unloading stress-strain function.
(Integer > 0)
EPSR Strain rate.
Default = 1.0 (Real)
FSCAL Scale factor for stress.
  1. The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT1.
  2. MATX65 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
  3. The material law is defined by pairs of stress functions for loading and unloading at a constant strain rate. For each strain rate, the yield stress is defined by the intersection between loading and unloading curves. Unloading follows unloading curve shifted by plastic strain value. Strain rates are interpolated using input values. In the elastic range, stress smaller than the yield value, the material behavior is elastic with hysteresis. It is limited by loading and unloading curves.
    Figure 1. Loading and Unloading Function Sets for Constant Strain Rates
    The Young's modulus must be greater than the maximum function slopes, and is used to follow loading and unloading paths between limiting curves.
    Figure 2. For a Constant Strain Rate, User-Defined Functions Set Limits for Cycling Loading
  4. This card is represented as a material in HyperMesh.
