MATX68
Bulk Data Entry Defines additional material properties for Honeycomb material for geometric nonlinear analysis. This law is only applicable to solid elements.
MATX68 | MID | ||||||||
TIID11 | TIID22 | TIID33 | IFLAG1 | FSCAI11 | FSCAI22 | FSCAI33 | |||
EPSFI11 | EPSFI22 | EPSFI33 | |||||||
TIID12 | TIID23 | TIID31 | IFLAG2 | FSCAI12 | FSCAI23 | FSCAI31 | |||
EPSFI12 | EPSFI23 | EPSFI31 | |||||||
TIID21 | TIID32 | TIID13 | FSCAI21 | FSCAI32 | FSCAI13 | ||||
TRID11 | TRID22 | TRID33 | FSCAR11 | FSCAR22 | FSCAR33 | ||||
EPST11 | EPST22 | EPST33 | |||||||
TRID12 | TRID23 | TRID31 | FSCAR12 | FSCAR23 | FSCAR31 | ||||
EPST12 | EPST23 | EPST31 | |||||||
TRID21 | TRID32 | TRID13 | FSCAR21 | FSCAR32 | FSCAR13 |
MAT9OR | 102 | 0.2 | 0.02 | 0.02 | 0.33 | 0.33 | 0.33 | 0.286E-7 | |
0.1 | 0.01 | 0.1 | |||||||
MATX68 | 102 | ||||||||
11 | 22 | 33 | NEGSTR | 1.0 | 1.0 | 1.0 | |||
0 | 0 | 0 | |||||||
12 | 23 | 31 | NEGSTR | 1.0 | 1.0 | 1.0 | |||
0.0 | 0.0 | 0.0 | |||||||
21 | 32 | 13 | 1.0 | 1.0 | 1.0 | ||||
11 | 22 | 33 | 1.0 | 1.0 | 1.0 | ||||
0.8 | 0.0 | 0.0 | |||||||
12 | 23 | 31 | 1.0 | 1.0 | 1.0 | ||||
MID | Material ID of the associated
MAT9OR. 1 No default (Integer > 0) |
TIID11 | Identification number of a
TABLES1 that defines initial yield stress function in
direction 11. No default (Integer > 0) |
TIID22 | Identification number of a
direction 22. No default (Integer > 0) |
TIID33 | Identification number of a
direction 33. No default (Integer > 0) |
IFLAG1 | Strain formulation for yield functions
11, 22, and 33. 4
FSCAI11 | Scale factor on initial yield stress
function in direction 11. Default = 1.0 (Real) |
FSCAI22 | Scale factor on initial yield stress
function in direction 22. Default = 1.0 (Real) |
FSCAI33 | Scale factor on initial yield stress
function in direction 33. Default = 1.0 (Real) |
EPSFI11 | Initial failure strain under tension
or compression in direction 11. (Real) |
EPSFI22 | Initial failure strain under tension
or compression in direction 22. (Real) |
EPSFI33 | Initial failure strain under tension
or compression in direction 33. (Real) |
TIID12 | Identification number of a
TABLES1 that defines initial shear yield stress function in
direction 12. No default (Integer > 0) |
TIID23 | Identification number of a
TABLES1 that defines Initial shear yield stress function in
direction 23. No default (Integer > 0) |
TIID31 | Identification number of a
direction 31. No default (Integer > 0) |
IFLAG2 | Strain formulation for yield functions
12, 23, and 31.
FSCAI12 | Scale factor on initial shear yield
stress function in direction 12. Default = 1.0 (Real) |
FSCAI23 | Scale factor on initial shear yield
stress function in direction 23. Default = 1.0 (Real) |
FSCAI31 | Scale factor on initial shear yield
stress function in direction 31. Default = 1.0 (Real) |
EPSFI12 | Initial failure strain under tension
or compression in direction 12. (Real) |
EPSFI23 | Initial failure strain under tension
or compression in direction 23. (Real) |
EPSFI31 | Initial failure strain under tension
or compression in direction 31. (Real) |
TIID21 | Identification number of a
direction 21. No default (Integer > 0) |
TIID32 | Identification number of a
direction 32. No default (Integer > 0) |
TIID13 | Identification number of a
direction 13. No default (Integer > 0) |
FSCAI21 | Scale factor on initial shear yield
stress function in direction 21. Default = 1.0 (Real) |
FSCAI32 | Scale factor on initial shear yield
stress function in direction 32. Default = 1.0 (Real) |
FSCAI13 | Scale factor on initial shear yield
stress function in direction 13. Default = 1.0 (Real) |
TRID11 | Identification number of a
TABLES1 that defines residual yield stress function in
TRID22 | Identification number of a
TRID33 | Identification number of a
FSCAR11 | Scale factor on residual yield stress
FSCAR22 | Scale factor on residual yield stress
FSCAR33 | Scale factor on residual yield stress
EPST11 | Transition strain in direction
11. (Real) |
EPST22 | Transition strain in direction
22. (Real) |
EPST33 | Transition strain in direction
33. (Real) |
TRID12 | Identification number of a
TABLES1 that defines residual shear yield stress function in
TRID23 | Identification number of a
TRID31 | Identification number of a
FSCAR12 | Scale factor on residual shear yield
FSCAR23 | Scale factor on residual shear yield
FSCAR31 | Scale factor on residual shear yield
EPST12 | Transition strain in direction
12. (Real) |
EPST23 | Transition strain in direction
23. (Real) |
EPST31 | Transition strain in direction
31. (Real) |
TRID21 | Identification number of a
TRID32 | Identification number of a
TRID13 | Identification number of a
FSCAR21 | Scale factor on residual shear yield
FSCAR32 | Scale factor on residual shear yield
FSCAR13 | Scale factor on residual shear yield
- The material identification number must be that of an existing MAT9OR Bulk Data Entry. Only one MATX68 material extension can be associated with a particular MAT9OR.
- MATX68 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- This law is compatible with 8 node brick elements with I =1 or I =2 on PSOLIDX only.
- When switching from a volumetric strain formulation to a strain formulation, IFLAGi = NEGSTR allows the same function definition to be retained.
- If one of the failure or shear failure strains is reached, the element is deleted.
- Transition strains define transition from initial yield stress function to residual yield stress function.
- If one of the transition or shear transition strains is reached, the element has yield stress described by residual functions in each direction. Transition is applied to the neighbor elements.
- This card is represented as extension to a MAT9OR material in HyperMesh.
