MBACT
Bulk Data Entry Defines the entity/set that needs to be activated in the multibody system for the subsequent simulation.
MBACT | ID | ETYPE | ID1 | ID2 | ID3 | etc |
or
MBACT | ID | ETYPE | IDST | THRU | IDEND |
MBACT | ID | MOTION | 92 |
ID | Unique identification number. (Integer > 0) |
ETYPE | Entity type that needs to be
activated.
ID1, ID2, ... | Entity/Set IDs that need to be
activated. (Integer > 0) |
IDST | Entity/Set ID range start. (Integer > 0) |
THRU | Keyword to indicate entity/set ID range is specified. | |
IDEND | Entity/Set ID range end. (Integer > IDST) |
- This card is represented as a load collector in HyperMesh.
