MBCNTDS
Bulk Data Entry Defines a Multibody Contact between a set of nodes and a deformable surface.
MBCNTDS CID SID SRFID CNFTYPE STIFF DAMP RADIUS
MBCNTDS 2 21 4 LINEAR 1E6 10 .1
CID Contact identification number.
No default (Integer > 0)
SID1 Set identification number of a set of nodes.
SRFID Multibody deformable surface (MBDSRF) identification number.
CNFTYPE Contact normal force type.
LINEAR
POISSON
No default (Character)
STIFF Specifies the interface stiffness coefficient, if CNFTYPE=LINEAR,
Specifies the penalty parameter which is related to the stiffness RJTODO, if CNFTYPE=POISSON.
Default = 0.0 (Real ≥ 0.0)
DAMP Specifies the interface damping, if CNFTYPE=LINEAR.
Default = 0.0 (Real ≥ 0)
Specifies the coefficient of restitution value for the contact, if CNFTYPE=POISSON.
Default = 1.0 (0.0 ≤ Real ≤ 1.0)
RADIUS Radius of the sphere geometry centered at the origin of the I marker.
  1. This card is represented as a group in HyperMesh.
