MBCRV
Bulk Data Entry Specifies the data used to define a curve.
MBCRV | CVID | LINEAR | |||||||
X1 | Y1 | X2 | Y2 | etc | etc | Xn | Yn |
MBCRV | 399 | ||||||||
1.0 | 1.1 | 2.0 | 0.0 | 3.0 | 14.2 | 4.0 | 19.9 | ||
5.0 | 12.1 |
CVID | Curve identification number. No default (Integer > 0) |
LINEAR | Linear extrapolation is used to
determine the curve data when the independent coordinate goes out of the range
specified on the Xi fields. If this field is blank, no extrapolation is applied and an ERROR is output when the independent coordinate goes out of range. Default = blank |
X1, X2, X3, ..., Xn | Independent curve data. No default (Real, X1 < X2 < X3 < ...) |
Y1, Y2, Y3, ..., Yn | Dependent curve data. No default (Real) |
- This card is represented as a curve in HyperMesh.
