MBCVCV
Bulk Data Entry Defines a Curve to Curve Constraint.
MBCVCV | JID | blank | PCID1 | G3 | V1 | ||||
blank | blank | PCID2 | G4 | V2 |
MBCVCV | 1 | 1 | 0 | 0 | |||||
2 | 0 | 1 |
JID | Joint identification
number. No default (Integer > 0) |
PCID1 | Parametric curve
(MBPCRV) identification number. No default (Integer > 0) |
PCID2 | Parametric curve
G3 | This grid specifies the
guess for the initial contact point on the first curve. Although this parameter is optional, specifying it helps the solver in determining the initial contact point. |
V1 | Specifies the sliding
velocity of the contact point relative to the part on which the
curve is etched. V1 is positive when contact
point is moving toward the start of the curve and
vice-versa. Default = 0.0 (Real) |
G4 | This grid specifies the
guess for the initial contact point on the second curve. Although this parameter is optional, specifying it helps the solver in determining the initial contact point. |
V2 | Specifies the sliding
curve is etched. V2 is positive when contact
