MBLIN
Bulk Data Entry Defines the parameters for a multibody system linear analysis.
MBLIN | ID | TYPE | ASCALE | ENGYDST | PID_IN | PID_OUT | NODAMP |
MBLIN | 99 | EIGEN | 1.0 |
ID | Unique identification number. (Integer > 0) |
TYPE | Linear analysis type.
ASCALE | Animation scale. Default = 1.0 (Real > 0.0) |
ENGYDST | Specifies whether the modal kinetic
energy distribution is written out to the solver log file and the
*_linz.mrf output file.
PID_IN | Specifies the plant input ID used for
the B and D state matrices. No default (Integer) |
PID_OUT | Specifies the plant output ID used for the C and D state matrices. | |
NODAMP | Specifies whether the linearization
solver disables damping from all force elements for the eigenvalue solution.
- For further information, refer to Parameters: Linear Static in the MotionSolve Reference Guide.
- This card is represented as a load collector in HyperMesh.
