MBPCRV
Bulk Data Entry Defines a Multibody Parametric Curve using node sets.
MBPCRV PCID UCLOSED CRVPTS
  G1 G2 G3 G4 G5
MBPCRV 1 1 0 1 5
  201 202 203 204 205
PCID Parametric curve identification number.
No default (Integer > 0)
UCLOSED Specify.
1
Closed curves
0
Open curves
CRVPTS Curve points.
1
If the curve must pass through the nodes
0 (Default)
If the B-spline curve does not pass through the nodes, but stays close.
(BOOLEAN: 0, 1)
G1,G2, ... Ordered list of grids defining the curve.
  1. This card is represented as a set in HyperMesh.
