MBPTCV
Bulk Data Entry Defines a Point to Parametric Curve Constraint.
MBPTCV JID GID PCID G3 V0
MBPTCV 1 21 2 25 0
JID Joint identification number.
No default (Integer > 0)
GID Grid identification number corresponding to the point which is sliding on a curve.
PCID Parametric curve (MBPCRV) identification number.
G3 This grid specifies the guess for the initial contact point on the curve.
Default is GID (Integer > 0)
V0 Specifies the initial sliding velocity of the contact point, as measured by an observer on the curve, placed at the contact point.
Default = 0.0 (Real)
